Amiga 2200(A1000Jr) - Η ξεχασμένη Amiga.
Το όνομα Commodore Amiga 2200 σας λέει κάτι? Εάν όχι(όπως και σε μένα), στα πιό κάτω links θα βρείτε πληροφορίες για τα δύο μοντέλα A2200-1(A2200, A2400) και A2200-2(A3200, A3400), όπως επίσης specifications και πολλές φωτογραφίες. Λίγα λόγια για τον υπολογιστή. Ήταν ένα μοντέλο κατασκευασμένο "within Commodore", που το έκανε στη πράξη μη υπαρκτό(non existent). Το A2200-1 είχε έναν 68020 cpu (2 x φορές ταχύτερη από μία A1200), 2MB 32bit chip ram and 2MB of fast (max στην mobo τα 8MBs). Η A2200-2(A3200) είχε CPU: 68030 & 68882 FPU στα 40mhz RAM: 2MB 32bit Chip ram και 4MB Fast Ram (128MB max στη mobo).
-- The A4000 form factor (i.e. case) was based off of this design. This board will fit into an A4000 case and will use an A4000 power supply. Keyboard connector appears the same as an A4000, but was not tested.
-- The ROMs appear to be standard A4000 V3.0 types. Not sure that these are the original ROMs, but seems reasonable given the similarity between the two machines.
-- The riser came in the same lot, but not the same box as the motherboard. Uncertain if it goes with the motherboard. However the A2400 (a 4-slot 2200) designation would seem to indicate that it is the proper one. The riser mechanically fits perfectly in the motherboard. System was tested without the riser installed to reduce the risk of any damage.
-- Battery is still attached and doesn’t appear to have leaked.
-- Board has 1MB of Chip RAM soldered on board with a 72-pin SIMM slot to expand.
-- Board has a 25mhz 68020 and 68882 on-board with an A3000/A4000 style fast-slot for expansion.
Τα links:
http://www.bigbookofamigahardware.com/bboah/product.aspx?id=2015
http://www.dfstudios.co.uk/crypt/Online/29/TheForgottenAmiga.html
Ειλικρινα δεν ήξερα καν ότι υπήρχε τέτοια amiga...δεν έφτασε ποτε ευρώπη φαντάζομαι...
